No masakra, teraz tutaj się nie chce w ogole zainstalować ta pandas
czytam i nie rozumiem gdzie jest błąd
że niby cos jest niezgodne jakies wersje ale nie widzę gdzie
bash-5.0# python3 -m pip install pandas
Collecting pandas
Using cached pandas-1.3.2.tar.gz (4.7 MB)
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /tmp/pip-standalone-pip-97uoni6z/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-acl4tulg/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=51.0.0' wheel 'Cython>=0.29.21,<3' 'numpy==1.17.3; python_version=='"'"'3.7'"'"' and (platform_machine!='"'"'arm64'"'"' or platform_system!='"'"'Darwin'"'"') and platform_machine!='"'"'aarch64'"'"'' 'numpy==1.18.3; python_version=='"'"'3.8'"'"' and (platform_machine!='"'"'arm64'"'"' or platform_system!='"'"'Darwin'"'"') and platform_machine!='"'"'aarch64'"'"'' 'numpy==1.19.3; python_version>='"'"'3.9'"'"' and (platform_machine!='"'"'arm64'"'"' or platform_system!='"'"'Darwin'"'"') and platform_machine!='"'"'aarch64'"'"'' 'numpy==1.19.2; python_version=='"'"'3.7'"'"' and platform_machine=='"'"'aarch64'"'"'' 'numpy==1.19.2; python_version=='"'"'3.8'"'"' and platform_machine=='"'"'aarch64'"'"'' 'numpy>=1.20.0; python_version=='"'"'3.8'"'"' and platform_machine=='"'"'arm64'"'"' and platform_system=='"'"'Darwin'"'"'' 'numpy>=1.20.0; python_version=='"'"'3.9'"'"' and platform_machine=='"'"'arm64'"'"' and platform_system=='"'"'Darwin'"'"''
cwd: None
Complete output (290 lines):
Ignoring numpy: markers 'python_version == "3.7" and (platform_machine != "arm64" or platform_system != "Darwin") and platform_machine != "aarch64"' don't match your environment
Ignoring numpy: markers 'python_version >= "3.9" and (platform_machine != "arm64" or platform_system != "Darwin") and platform_machine != "aarch64"' don't match your environment
Ignoring numpy: markers 'python_version == "3.7" and platform_machine == "aarch64"' don't match your environment
Ignoring numpy: markers 'python_version == "3.8" and platform_machine == "aarch64"' don't match your environment
Ignoring numpy: markers 'python_version == "3.8" and platform_machine == "arm64" and platform_system == "Darwin"' don't match your environment
Ignoring numpy: markers 'python_version == "3.9" and platform_machine == "arm64" and platform_system == "Darwin"' don't match your environment
Collecting setuptools>=51.0.0
Using cached setuptools-57.4.0-py3-none-any.whl (819 kB)
Collecting wheel
Using cached wheel-0.37.0-py2.py3-none-any.whl (35 kB)
Collecting Cython<3,>=0.29.21
Using cached Cython-0.29.24-py2.py3-none-any.whl (979 kB)
Collecting numpy==1.18.3
Using cached numpy-1.18.3.zip (5.4 MB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing wheel metadata: started
Preparing wheel metadata: still running...
Preparing wheel metadata: finished with status 'error'
command: /usr/bin/python3 /tmp/tmpvhtmtb45 prepare_metadata_for_build_wheel /tmp/tmp0ej9znqp
cwd: /tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac
Complete output (261 lines):
Processing numpy/random/_bounded_integers.pxd.in
Processing numpy/random/_mt19937.pyx
Processing numpy/random/_generator.pyx
Processing numpy/random/_philox.pyx
Processing numpy/random/_bit_generator.pyx
Processing numpy/random/_bounded_integers.pyx.in
Processing numpy/random/_common.pyx
Processing numpy/random/_sfc64.pyx
Processing numpy/random/_pcg64.pyx
Processing numpy/random/mtrand.pyx
Cythonizing sources
blas_opt_info:
blas_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
blis_info:
libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
openblas_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
atlas_3_10_blas_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
blas_info:
libraries blas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
blas_src_info:
NOT AVAILABLE
NOT AVAILABLE
non-existing path in 'numpy/distutils': 'site.cfg'
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
openblas_lapack_info:
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
flame_info:
libraries flame not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
atlas_3_10_threads_info:
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib/
libraries tatlas,tatlas not found in /usr/lib/
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/']
NOT AVAILABLE
lapack_src_info:
NOT AVAILABLE
NOT AVAILABLE
running dist_info
running build_src
build_src
building py_modules sources
creating build
creating build/src.linux-x86_64-3.8
creating build/src.linux-x86_64-3.8/numpy
creating build/src.linux-x86_64-3.8/numpy/distutils
building library "npymath" sources
Could not locate executable gfortran
Could not locate executable f95
Could not locate executable ifort
Could not locate executable ifc
Could not locate executable lf95
Could not locate executable pgfortran
Could not locate executable f90
Could not locate executable f77
Could not locate executable fort
Could not locate executable efort
Could not locate executable efc
Could not locate executable g77
Could not locate executable g95
Could not locate executable pathf95
Could not locate executable nagfor
don't know how to compile Fortran code on platform 'posix'
creating build/src.linux-x86_64-3.8/numpy/core
creating build/src.linux-x86_64-3.8/numpy/core/src
creating build/src.linux-x86_64-3.8/numpy/core/src/npymath
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npymath/npy_math_internal.h
adding 'build/src.linux-x86_64-3.8/numpy/core/src/npymath' to include_dirs.
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npymath/ieee754.c
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npymath/npy_math_complex.c
None - nothing done with h_files = ['build/src.linux-x86_64-3.8/numpy/core/src/npymath/npy_math_internal.h']
building library "npysort" sources
creating build/src.linux-x86_64-3.8/numpy/core/src/common
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/common/npy_sort.h
adding 'build/src.linux-x86_64-3.8/numpy/core/src/common' to include_dirs.
creating build/src.linux-x86_64-3.8/numpy/core/src/npysort
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npysort/quicksort.c
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npysort/mergesort.c
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npysort/timsort.c
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npysort/heapsort.c
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npysort/radixsort.c
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/common/npy_partition.h
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npysort/selection.c
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/common/npy_binsearch.h
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/npysort/binsearch.c
None - nothing done with h_files = ['build/src.linux-x86_64-3.8/numpy/core/src/common/npy_sort.h', 'build/src.linux-x86_64-3.8/numpy/core/src/common/npy_partition.h', 'build/src.linux-x86_64-3.8/numpy/core/src/common/npy_binsearch.h']
building extension "numpy.core._multiarray_tests" sources
creating build/src.linux-x86_64-3.8/numpy/core/src/multiarray
conv_template:> build/src.linux-x86_64-3.8/numpy/core/src/multiarray/_multiarray_tests.c
building extension "numpy.core._multiarray_umath" sources
Running from numpy source directory.
setup.py:461: UserWarning: Unrecognized setuptools command, proceeding with generating Cython sources and expanding templates
run_build = parse_setuppy_commands()
/tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac/numpy/distutils/system_info.py:1896: UserWarning:
Optimized (vendor) Blas libraries are not found.
Falls back to netlib Blas library which has worse performance.
A better performance should be easily gained by switching
Blas library.
if self._calc_info(blas):
Blas (http://www.netlib.org/blas/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [blas]) or by setting
the BLAS environment variable.
Blas (http://www.netlib.org/blas/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [blas_src]) or by setting
the BLAS_SRC environment variable.
/tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac/numpy/distutils/system_info.py:1730: UserWarning:
Lapack (http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
return getattr(self, '_calc_info_{}'.format(name))()
Lapack (http://www.netlib.org/lapack/) sources not found.
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
/usr/lib/python3.8/distutils/dist.py:274: UserWarning: Unknown distribution option: 'define_macros'
warnings.warn(msg)
File "/tmp/tmpvhtmtb45", line 349, in <module>
main()
File "/tmp/tmpvhtmtb45", line 331, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/tmp/tmpvhtmtb45", line 151, in prepare_metadata_for_build_wheel
return hook(metadata_directory, config_settings)
File "/tmp/pip-build-env-tptxwwhy/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 166, in prepare_metadata_for_build_wheel
self.run_setup()
File "/tmp/pip-build-env-tptxwwhy/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 258, in run_setup
super(_BuildMetaLegacyBackend,
File "/tmp/pip-build-env-tptxwwhy/overlay/lib/python3.8/site-packages/setuptools/build_meta.py", line 150, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 488, in <module>
setup_package()
File "setup.py", line 480, in setup_package
setup(**metadata)
File "/tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac/numpy/distutils/core.py", line 171, in setup
return old_setup(**new_attr)
File "/tmp/pip-build-env-tptxwwhy/overlay/lib/python3.8/site-packages/setuptools/__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.8/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.8/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.8/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/tmp/pip-build-env-tptxwwhy/overlay/lib/python3.8/site-packages/setuptools/command/dist_info.py", line 31, in run
egg_info.run()
File "/tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac/numpy/distutils/command/egg_info.py", line 26, in run
self.run_command("build_src")
File "/usr/lib/python3.8/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac/numpy/distutils/command/build_src.py", line 146, in run
self.build_sources()
File "/tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac/numpy/distutils/command/build_src.py", line 163, in build_sources
self.build_extension_sources(ext)
File "/tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac/numpy/distutils/command/build_src.py", line 320, in build_extension_sources
sources = self.generate_sources(sources, ext)
File "/tmp/pip-install-hcyrvo44/numpy_7a9a095ab7e943f792dd47e607777aac/numpy/distutils/command/build_src.py", line 380, in generate_sources
source = func(extension, build_dir)
File "numpy/core/setup.py", line 430, in generate_config_h
moredefs, ignored = cocache.check_types(config_cmd, ext, build_dir)
File "numpy/core/setup.py", line 49, in check_types
out = check_types(*a, **kw)
File "numpy/core/setup.py", line 286, in check_types
raise SystemError(
SystemError: Cannot compile 'Python.h'. Perhaps you need to install python-dev|python-devel.
WARNING: Discarding https://files.pythonhosted.org/packages/0c/e8/c49cb52ed2ad734efb49eb1f7766888b0e65df1848f71fa7f7fd52183392/numpy-1.18.3.zip#sha256=e46e2384209c91996d5ec16744234d1c906ab79a701ce1a26155c9ec890b8dc8 (from https://pypi.org/simple/numpy/) (requires-python:>=3.5). Command errored out with exit status 1: /usr/bin/python3 /tmp/tmpvhtmtb45 prepare_metadata_for_build_wheel /tmp/tmp0ej9znqp Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement numpy==1.18.3 (from versions: 1.3.0, 1.4.1, 1.5.0, 1.5.1, 1.6.0, 1.6.1, 1.6.2, 1.7.0, 1.7.1, 1.7.2, 1.8.0, 1.8.1, 1.8.2, 1.9.0, 1.9.1, 1.9.2, 1.9.3, 1.10.0.post2, 1.10.1, 1.10.2, 1.10.4, 1.11.0, 1.11.1, 1.11.2, 1.11.3, 1.12.0, 1.12.1, 1.13.0rc1, 1.13.0rc2, 1.13.0, 1.13.1, 1.13.3, 1.14.0rc1, 1.14.0, 1.14.1, 1.14.2, 1.14.3, 1.14.4, 1.14.5, 1.14.6, 1.15.0rc1, 1.15.0rc2, 1.15.0, 1.15.1, 1.15.2, 1.15.3, 1.15.4, 1.16.0rc1, 1.16.0rc2, 1.16.0, 1.16.1, 1.16.2, 1.16.3, 1.16.4, 1.16.5, 1.16.6, 1.17.0rc1, 1.17.0rc2, 1.17.0, 1.17.1, 1.17.2, 1.17.3, 1.17.4, 1.17.5, 1.18.0rc1, 1.18.0, 1.18.1, 1.18.2, 1.18.3, 1.18.4, 1.18.5, 1.19.0rc1, 1.19.0rc2, 1.19.0, 1.19.1, 1.19.2, 1.19.3, 1.19.4, 1.19.5, 1.20.0rc1, 1.20.0rc2, 1.20.0, 1.20.1, 1.20.2, 1.20.3, 1.21.0rc1, 1.21.0rc2, 1.21.0, 1.21.1, 1.21.2)
ERROR: No matching distribution found for numpy==1.18.3
WARNING: Discarding https://files.pythonhosted.org/packages/cf/f7/6c0dd488b5f5f1c0c1a48637df45046334d0be684faaf3536429f14aa9de/pandas-1.3.2.tar.gz#sha256=cbcb84d63867af3411fa063af3de64902665bb5b3d40b25b2059e40603594e87 (from https://pypi.org/simple/pandas/) (requires-python:>=3.7.1). Command errored out with exit status 1: /usr/bin/python3 /tmp/pip-standalone-pip-97uoni6z/__env_pip__.zip/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-acl4tulg/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=51.0.0' wheel 'Cython>=0.29.21,<3' 'numpy==1.17.3; python_version=='"'"'3.7'"'"' and (platform_machine!='"'"'arm64'"'"' or platform_system!='"'"'Darwin'"'"') and platform_machine!='"'"'aarch64'"'"'' 'numpy==1.18.3; python_version=='"'"'3.8'"'"' and (platform_machine!='"'"'arm64'"'"' or platform_system!='"'"'Darwin'"'"') and platform_machine!='"'"'aarch64'"'"'' 'numpy==1.19.3; python_version>='"'"'3.9'"'"' and (platform_machine!='"'"'arm64'"'"' or platform_system!='"'"'Darwin'"'"') and platform_machine!='"'"'aarch64'"'"'' 'numpy==1.19.2; python_version=='"'"'3.7'"'"' and platform_machine=='"'"'aarch64'"'"'' 'numpy==1.19.2; python_version=='"'"'3.8'"'"' and platform_machine=='"'"'aarch64'"'"'' 'numpy>=1.20.0; python_version=='"'"'3.8'"'"' and platform_machine=='"'"'arm64'"'"' and platform_system=='"'"'Darwin'"'"'' 'numpy>=1.20.0; python_version=='"'"'3.9'"'"' and platform_machine=='"'"'arm64'"'"' and platform_system=='"'"'Darwin'"'"'' Check the logs for full command output.
