Cześć
Znalazłem takiego gotowca na ściąganie danych z pieca który ma sterownik na wi fi.
sensor.yaml
EcoNET boiler
- platform: rest
scan_interval: 300
resource: !secret econet24_host
method: GET
verify_ssl: false
username: !secret econet24_user
password: !secret econet24_psw
authentication: basic
headers:
User-Agent: Home Assistant
Content-Type: application/json
value_template: “OK”
json_attributes:- curr
- fuelLevel
- platform: template
sensors:
boiler_fuellevel:
friendly_name: Fuel Level
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“fuelLevel”] }}’
device_class: battery
unit_of_measurement: “%”
boiler_temperature:
friendly_name: Boiler Temperature
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“tempCO”]|int }}’
device_class: temperature
unit_of_measurement: “°C”
icon_template: mdi:thermometer-lines
boiler_pumpcoworks:
friendly_name: Boiler Operation
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“pumpCOWorks”] }}’
boiler_output:
friendly_name: Boiler Power
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“boilerPower”] }}’
boiler_fan_output:
friendly_name: Boiler Fan Output
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“fanPower”]|int }}’
icon_template: mdi:fan
boiler_mixer_set_temp1:
friendly_name: Boiler Mixer Heat Set Temperature
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“mixerSetTemp1”]|int }}’
boiler_mixer_temp1:
friendly_name: Boiler Mixer 1 Temperature
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“mixerTemp1”]|int }}’
boiler_temp_huw_set:
friendly_name: Boiler Set Hot Water
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“tempCWUSet”] }}’
temp_huw:
friendly_name: Hot Water
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“tempCWU”]|int }}’
temp_outside:
friendly_name: Temperature Outside
value_template: ‘{{states.sensor.Boiler.attributes[“curr”][“tempExternalSensor”]|int }}’
Rozumiem że mma utworzyć plik sensor.yaml, wkleić tą formułę, dać swoje dane logowania i… i co dalej? Z takiego pliku robi się encję czy uruchamia się go z konsoli? przy username i password formuła !secret zostaje czy ją usuwam?
Sorki dopiero zaczynam przygodę z AI-S a z programowałem tylko maszyny CNC a nie takie skrypty
pomysłów mam dużo ale potrzebne mi są mądre głowy z naszego forum.
