Witam
Jako ze kurzy się to chciałem sobie pudełko wykorzystać i potrzebuje źródło do plików linuxa na dev 3, niestety wszystkie linki co znalazlem są nieaktualne
w skrócie chce zainstalować samecgo linuxa na dev 3
Może ktoś ma jeszcze takie do pobrania?
DEV3 to jest prawdopodobnie tv-box o nazwie kodowej (X88 Pro Pro X3 / X99 Max Plus / Transpeed X3 Plus) lub być może TX3
Armbian for Amlogic s9xxx tv box. Support a311d, s922x, s905x3, s905x2, s912, s905d, s905x, s905w, s905, etc. including install to EMMC and update related functions.
# The files description
The list of devices supported by Amlogic TV Boxes, the configuration file in the `Armbian` system is [/etc/amlogic_model_database.conf](../common-files/rootfs/etc/amlogic_model_database.conf), and the configuration file in the `OpenWrt` system is [/etc/model_database.txt](https://github.com/ophub/amlogic-s9xxx-openwrt/blob/main/amlogic-s9xxx/common-files/rootfs/etc/model_database.txt) When you are using Armbian with kernel version 5.10.y and above, you need to copy the corresponding `u-boot-xxx.bin` file in the `overload` directory as `u-boot.ext`, when using in eMMC, you need to copy as `u-boot.emmc`. Some devices need to write the corresponding `bootloader` file.
These duplications are automated in the repository's packaging and install/update scripts, eliminating the need for manual duplication.
## The list of devices supported by Amlogic TV Boxes
<table cellpadding="0" cellspacing="0">
<tr><td>ID</td><td>Model Name</td><td>SOC</td><td>FDTFILE</td><td>UBOOT_OVERLOAD</td><td>MAINLINE_UBOOT</td><td>ANDROID_UBOOT</td><td>Brief Description</td></tr>
<tr><td>101</td><td>Phicomm N1</td><td>s905d</td><td>meson-gxl-s905d-phicomm-n1.dtb</td><td>u-boot-n1.bin</td><td>NA</td><td>u-boot-2015-phicomm-n1.bin</td><td>4C@1512Mhz,2GB Mem,1Gb Nic,Wifi</td></tr>
<tr><td>102</td><td>Phicomm N1(DMA thresh)</td><td>s905d</td><td>meson-gxl-s905d-phicomm-n1-thresh.dtb</td><td>u-boot-n1.bin</td><td>NA</td><td>u-boot-2015-phicomm-n1.bin</td><td>Same as above, when ethmac flow control is off</td></tr>
<tr><td>103</td><td>HG680P & TBee Box</td><td>s905x</td><td>meson-gxl-s905x-p212.dtb</td><td>u-boot-p212.bin</td><td>NA</td><td>NA</td><td>4C@1512Mhz,100Mb Nic</td></tr>
<tr><td>104</td><td>X96-Mini & TX3-Mini</td><td>s905w</td><td>meson-gxl-s905w-tx3-mini.dtb</td><td>u-boot-s905x-s912.bin</td><td>NA</td><td>NA</td><td>4C@1512Mhz,100Mb Nic</td></tr>
<tr><td>105</td><td>MECOOL KI Pro</td><td>s905d</td><td>meson-gxl-s905d-mecool-ki-pro.dtb</td><td>u-boot-p201.bin</td><td>NA</td><td>NA</td><td>2G/16G,1Gb Nic</td></tr>
<tr><td>106</td><td>T95</td><td>s905x</td><td>meson-gxl-s905x-p212.dtb</td><td>u-boot-s905x-s912.bin</td><td>NA</td><td>NA</td><td>1+8G,100Mb Nic(Use: extlinux/extlinux.conf)</td></tr>
<tr><td>107</td><td>B860H</td><td>s905x</td><td>meson-gxl-s905x-b860h.dtb</td><td>u-boot-p212.bin</td><td>NA</td><td>NA</td><td>4C@1512Mhz,100Mb Nic</td></tr>
<tr><td>201</td><td>Octopus Planet</td><td>s912</td><td>meson-gxm-octopus-planet.dtb</td><td>u-boot-zyxq.bin</td><td>NA</td><td>NA</td><td>4C@1512Mhz+4C@1000Mhz,2GB Mem,1Gb Nic</td></tr>
<tr><td>202</td><td>Octopus Planet (FAKE)</td><td>s912</td><td>meson-gxm-octopus-planet.dtb</td><td>u-boot-zyxq.bin</td><td>NA</td><td>bl-fake-octopus-planet.bin</td><td>4C@1512Mhz+4C@1000Mhz,2GB Mem,1Gb Nic</td></tr>
Ten plik został obcięty. pokaż oryginał
to wyżej to fork z tego projektu (tam też jest dokumentacja nawet chyba aktualniejsza i bardziej rozbudowana)
Supports running Armbian on Amlogic, Allwinner, and Rockchip devices. Support a311d, s922x, s905x3, s905x2, s912, s905d, s905x, s905w, s905, s905l, rk3588, rk3568, rk3399, rk3328, h6, etc.
Te najświeższa jeszcze działają:
Skoro to jest ten sam sprzęt co DEV3, to jest to nadzieja dla dotychczasowych użytkowników DEV3 na wykorzystanie sprzętu też do innych celów (niż aktualne HA)
wykorzystując dokumentację
oraz ewentualnie obraz systemu
w dokumentacji jest informacja też o wydaniach innych systemów z rodzin: linux oraz android, w tym umożliwiające uzyskanie funkcji androidowego tv-boxa.
Wielkie dzieki ściągnąłem wszystko co się dalo żebym miał do wyboru
damu
20 Czerwiec 2026 20:19
5
Też muszę odkurzyć Dev3, dzięki za info.
