Jako, że nie udało mi się zintegrować projektu https://diyhue.org/ z asystentem, poszukałem dalej i znalazłem coś skrojonego na miarę czyli
https://github.com/Dullage/ESP-LED-MQTT
Sama lampka śmiga i widzę ją w drzewku homeassistant w brokerze mqtt asystenta (przez mqtt explorer), w README są jakieś przykłady konfigów HA ale nie wiem dokładnie to wstawić albo dodać przez UI asystenta. Wiecie jak to zintegrować ?
Home Assistant Examples
light: Basic control of a light.
- platform: mqtt
state_topic: "light/lamp/state"
command_topic: "light/lamp"
rgb_state_topic: "light/lamp/rgb/state"
rgb_command_topic: "light/lamp/rgb"
availability_topic: "light/lamp/availability"
payload_not_available: "0"
payload_available: "1"
payload_off: "0"
payload_on: "1"
retain: false
Note: The recovery topic does not need to be used in the Home Assistant config.
input_select: UI to allow user to trigger an animation.
lamp:
options:
- "Select..."
- "Warm Light"
- "Strobe"
- "Fire"
- "Colour Phase"
- "Sparkle"
- "Shoot / Drip"
- "Rain"
- "Rainbow 1"
- "Rainbow 2"
initial: "Select..."
automation: Sends the appropriate MQTT command when a mode is selected and then returns the input select back to ‘Select…’
- alias: "Lamp Mode"
trigger:
platform: state
entity_id: input_select.lamp
action:
- service: mqtt.publish
data_template:
topic: "switch/stairs"
payload: >
{% if trigger.to_state.state == 'Warm Light' %}
{0:2,2:[255,147,41]}
{% elif trigger.to_state.state == 'Strobe' %}
{0:3}
{% elif trigger.to_state.state == 'Fire' %}
{0:4}
{% elif trigger.to_state.state == 'Colour Phase' %}
{0:5,3:15}
{% elif trigger.to_state.state == 'Sparkle' %}
{0:6,2:[50,50,50],3:0,4:5,5:0}
{% elif trigger.to_state.state == 'Shoot / Drip' %}
{0:7,2:[255,147,41],8:0,10:1,9:30, 5:0 ,4:255,3:0,12:5,7:0}
{% elif trigger.to_state.state == 'Rain' %}
{0:8,11:1100}
{% elif trigger.to_state.state == 'Rainbow 1' %}
{0:12}
{% elif trigger.to_state.state == 'Rainbow 2' %}
{0:13}
{% else %}
{% endif %}
retain: false
- service: input_select.select_option
entity_id: input_select.stairlamp_mode
option: 'Select...'
