Onvif integracja
Dziś próbowałem uruchomić integracje onvif i wyrzuciło mi błąd.
Logi poniżej :slightly_smiling_face:
KKtos wie czemu nie można zainstalować integracji ?
Logger: aiohttp.server
Source: requirements.py:138
First occurred: 5:45:52 (1 occurrences)
Last logged: 5:45:52
Error handling request
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/aiohttp/web_protocol.py”, line 422, in _handle_request
resp = await self._request_handler(request)
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/aiohttp/web_app.py”, line 499, in _handle
resp = await handler(request)
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/http/security_filter.py”, line 56, in security_filter_middleware
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/http/request_context.py”, line 18, in request_context_middleware
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/http/ban.py”, line 74, in ban_middleware
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/http/auth.py”, line 135, in auth_middleware
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/http/view.py”, line 131, in handle
result = await result
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/config/config_entries.py”, line 128, in post
return await super().post(request)
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/http/data_validator.py”, line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/helpers/data_entry_flow.py”, line 70, in post
result = await self._flow_mgr.async_init(
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/data_entry_flow.py”, line 120, in async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/config_entries.py”, line 570, in async_create_flow
await async_process_deps_reqs(self.hass, self._hass_config, integration)
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/setup.py”, line 373, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/requirements.py”, line 81, in async_get_integration_with_requirements
await async_process_requirements(
File “/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/requirements.py”, line 138, in async_process_requirements
raise RequirementsNotFound(name, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for onvif not found: [‘onvif-zeep-async==1.0.0’].
Mi dodatkowo pojawiły się poniższe błędy po restarcie bramki i przywróceniu ręcznym konfiguracji ;/ może ktoś wie jak się ich pozbyć?
Brakuje pakietu, trzeba go doinstalować, standardowo w linuxie to polecenie:
pip install onvif-zeep-async
ale nie wiem czy tak samo zadziała na bramce AIS, z przejrzanych postów wynika, że powinno być OK.
Natomiast z tego rysunku:
wynika, że brakuje innych zależności/jest konflikt do poprawnego zainstalowania tego pakietu.
dzięki :beers:, po instalacji wróciło wszystko do normy
Ja sprawdzę dopiero jutro :slightly_smiling_face:
Ale super że udało się to zdiagnozować. :slightly_smiling_face:
Witaj. Czyli dosintalowałeś pakiet i integrację i wszystko jest ok? Nie mam doświadczenia; napisz proszę więcej coś o tej integracji. Dzięki :slight_smile:
Pozdrowienia
integrację miałem ale robiłem restart bramki i przywracałem konfigurację ręcznie z backupu na dysku, i jak się okazało i napisał ‘macek’ po resecie nie doinstalował się pakiet onvif-zeep-async
Po jego instalacji wszystko wróciło do normy
Potwierdzam.
Wszystko ruszyło :slightly_smiling_face:
@jolka wiadomo czemu bramka ma problem z tym pakietem?
Witajcie. Napiszcie proszę Panowie czy jest różnica w wydajności obsługi kamer pomiędzy dwoma rozwiązaniami, czyli Onvif lub bezpośrednio poprzez HA:
Jaki macie doświadczenia?
Jeśli chodzi o sam obraz to nie ma żadnej różnicy, stream musi być i tak zdekodowany przez bramkę (niestety softwarowo) więc obciążenie będzie takie samo. Na korzyść ONVIF jest zestandaryzowanie obsługi wszystkich “bajerów” jakie obsługuje kamera, np. alarmy , MD, PTZ, itp. Nie trzeba się bawić w ręczną konfigurację bo teoretycznie wszystko powinno być wykryte prze tę integrację.
Bardzo Ci dziękuję.
Jeżeli masz Dev3 to wg Ciebie daje radę?
Wszystko zależy od kodeka i rozdzielczości - ja mam kamery z kodekiem h265 i matrycami 6Mpix i na to nie ma szans na live stream. próbowałem też substream ustawić na h264 PAL i tutaj jakoś szło, ale moje osobiste zdanie jest takie, że szkoda “katować” bramki takimi streamami bo staje się mniej responsywna i stabilna.
Dziękuję za wiadomości i ślę pozdrowienia :slightly_smiling_face:
mam 4 kamery na onvif, jak dodac je do bramki i lovelance?
Pomoze ktos, moze jakis przyklad.
Najprościej przez Integracje.
Konfiguracja → Integracje
Tam wyszukaj ONVIF i zainstaluj ją… dalej chyba sobie poradzisz?
A czy przez tunel od AIS podgląd kamer pójdzie? Czy tylko w sieci lokalnej?
Działa bez problemu przez tunel.
Po aktualizacji do termux mam problem z kamerami. Zaktualizowałem pip i onvif ale kamer brak.
Dostaje tylko to w logach.
Logger: homeassistant.components.onvif
Source: components/onvif/device.py:137
Integration: ONVIF (documentation, issues)
First occurred: 21:26:17 (5 occurrences)
Last logged: 21:31:37
Couldn’t connect to camera ‘Lechange’, please verify that the credentials are correct. Error: Invalid data
Couldn’t connect to camera 'Wejście ', please verify that the credentials are correct. Error: Invalid data
