Witajcie przez pewien czas było dobrze od dwóch dni znowu pojawił się problem z zigbee.
chociaż serwis zigbee stoi
podmiana zigbee w inny port nic ni daje. dopiero nie restart zigbee service tylko restart bramki mam jeszcze dev1.
Koś ma podobnie
Error Publish 'set' 'state' to 'Nowa Kuchnia3' failed: 'Error: Command 0x842e14fffe27084b/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
Info MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to 'Nowa Kuchnia3' failed: 'Error: Command 0x842e14fffe27084b/1 genOnOff.off({}, {\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null,\"writeUndiv\":false}) failed (SRSP - AF - dataRequest after 6000ms)'","meta":{"friendly_name":"Nowa Kuchnia3"},"type":"zigbee_publish_error"}'
Error Publish 'set' 'state' to 'Nowa Kuchnia1' failed: 'Error: Command 0x842e14fffe11d3d8/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (SRSP - AF - dataRequest after 6000ms)'
