Cześć,
Po dodaniu integracji z influxdb według tego poradnika:
InfluxDB w AIS dom - faq - AI-Speaker
podczas uruchamiania bramki w logach widzę taki wpis:
> Logger: root Source: components/influxdb/__init__.py:357 First occurred: 10:42:39 PM (1 occurrences) Last logged: 10:42:39 PM Uncaught thread exception Traceback (most recent call last): File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/multiprocessing/synchronize.py", line 28, in <module> from _multiprocessing import SemLock, sem_unlink ImportError: cannot import name 'SemLock' from '_multiprocessing' (/data/data/pl.sviete.dom/files/usr/lib/python3.9/lib-dynload/_multiprocessing.cpython-39.so) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/threading.py", line 954, in _bootstrap_inner self.run() File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/influxdb/__init__.py", line 582, in run self.write_to_influxdb(json) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/influxdb/__init__.py", line 558, in write_to_influxdb self.influx.write(json) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/influxdb/__init__.py", line 357, in write_v2 write_api.write(**data) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/influxdb_client/client/write_api.py", line 251, in write results = list(map(write_payload, payloads.items())) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/influxdb_client/client/write_api.py", line 249, in write_payload return self._post_write(_async_req, bucket, org, final_string, payload[0]) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/influxdb_client/client/write_api.py", line 366, in _post_write return self._write_service.post_write(org=org, bucket=bucket, body=body, precision=precision, File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/influxdb_client/service/write_service.py", line 62, in post_write return self.post_write_with_http_info(org, bucket, body, **kwargs) # noqa: E501 File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/influxdb_client/service/write_service.py", line 168, in post_write_with_http_info return self.api_client.call_api( File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/influxdb_client/api_client.py", line 347, in call_api thread = self.pool.apply_async(self.__call_api, (resource_path, File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/influxdb_client/api_client.py", line 94, in pool self._pool = ThreadPool(self.pool_threads) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/multiprocessing/pool.py", line 927, in __init__ Pool.__init__(self, processes, initializer, initargs) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/multiprocessing/pool.py", line 196, in __init__ self._change_notifier = self._ctx.SimpleQueue() File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/multiprocessing/context.py", line 113, in SimpleQueue return SimpleQueue(ctx=self.get_context()) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/multiprocessing/queues.py", line 342, in __init__ self._rlock = ctx.Lock() File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/multiprocessing/context.py", line 67, in Lock from .synchronize import Lock File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/multiprocessing/synchronize.py", line 30, in <module> raise ImportError("This platform lacks a functioning sem_open" + ImportError: This platform lacks a functioning sem_open implementation, therefore, the required synchronization primitives needed will not function, see issue 3770.
Ktoś ma pomysł jak sobie z tym poradzić? Jak się łatwo można domyślić - integracja nie działa ![]()
Robert
