Wczoraj dodałem MagicHome do systemu, wszystko śmiga ale w logach wali błąd:
Logger: homeassistant.util.logging
Source: util/logging.py:107
First occurred: 21:10:11 (2 occurrences)
Last logged: 21:10:13
* Exception in rgb_received when handling msg on 'tele/dom_C7DFF1/STATE': '{"Time":"2021-03-27T21:10:12","Uptime":"0T10:12:19","UptimeSec":36739,"Heap":22,"SleepMode":"Dynamic","Sleep":10,"LoadAvg":49,"MqttCount":1,"POWER":"ON","Dimmer":89,"Color":"00E420","HSBColor":"128,100,89","Channel":[0,89,13],"Scheme":0,"Fade":"OFF","Speed":2,"LedTable":"ON","Wifi":{"AP":1,"SSId":"iot","BSSId":"86:AC:B9:6A:D3:D8","Channel":6,"RSSI":68,"Signal":-66,"LinkCount":1,"Downtime":"0T00:00:03"}}' Traceback (most recent call last): File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/mqtt/debug_info.py", line 35, in wrapper msg_callback(msg) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/mqtt/light/schema_basic.py", line 335, in rgb_received rgb = [int(val) for val in payload.split(",")] File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/mqtt/light/schema_basic.py", line 335, in <listcomp> rgb = [int(val) for val in payload.split(",")] ValueError: invalid literal for int() with base 10: '00E420'
* Exception in rgb_received when handling msg on 'tele/dom_C7DFF1/STATE': '{"Time":"2021-03-27T21:10:14","Uptime":"0T10:12:21","UptimeSec":36741,"Heap":22,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":66,"MqttCount":1,"POWER":"OFF","Dimmer":89,"Color":"00E420","HSBColor":"128,100,89","Channel":[0,89,13],"Scheme":0,"Fade":"OFF","Speed":2,"LedTable":"ON","Wifi":{"AP":1,"SSId":"iot","BSSId":"86:AC:B9:6A:D3:D8","Channel":6,"RSSI":70,"Signal":-65,"LinkCount":1,"Downtime":"0T00:00:03"}}' Traceback (most recent call last): File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/mqtt/debug_info.py", line 35, in wrapper msg_callback(msg) File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/mqtt/light/schema_basic.py", line 335, in rgb_received rgb = [int(val) for val in payload.split(",")] File "/data/data/pl.sviete.dom/files/usr/lib/python3.9/site-packages/homeassistant/components/mqtt/light/schema_basic.py", line 335, in <listcomp> rgb = [int(val) for val in payload.split(",")] ValueError: invalid literal for int() with base 10: '00E420'
też macie to w logach ?
