Witam,
Zakupiłem w promocji 11.11 z aliexpress syrenę alarmową z termometrem i pomiarem wilgotności, która według informacji na zigbee2mqtt.io jest kompatybilna z Zigbee2Mqtt.
Jednak u mnie przy próbie parowania mam w logach takie informacje:
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/response/device/remove’, payload ‘{“data”:{“block”:false,“force”:true,“id”:“0x842e14fffedb841a”},“status”:“ok”}’
INFO: Device ‘0x842e14fffedb841a’ joined
INFO: Starting interview of ‘0x842e14fffedb841a’
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0x842e14fffedb841a”,“ieee_address”:“0x842e14fffedb841a”},“type”:“device_joined”}’
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0x842e14fffedb841a”,“ieee_address”:“0x842e14fffedb841a”,“status”:“started”},“type”:“device_interview”}’
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/log’, payload ‘{“message”:{“friendly_name”:“0x842e14fffedb841a”},“type”:“device_connected”}’
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/log’, payload ‘{“message”:“interview_started”,“meta”:{“friendly_name”:“0x842e14fffedb841a”},“type”:“pairing”}’
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“friendly_name”:“0x842e14fffedb841a”,“ieee_address”:“0x842e14fffedb841a”},“type”:“device_announce”}’
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/log’, payload ‘{“message”:“announce”,“meta”:{“friendly_name”:“0x842e14fffedb841a”},“type”:“device_announced”}’
INFO: Successfully interviewed ‘0x842e14fffedb841a’, device has successfully been paired
WARNING: Device ‘0x842e14fffedb841a’ with Zigbee model ‘TS0601’ is NOT supported, please follow | Zigbee2MQTT
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/event’, payload ‘{“data”:{“definition”:null,“friendly_name”:“0x842e14fffedb841a”,“ieee_address”:“0x842e14fffedb841a”,“status”:“successful”,“supported”:false},“type”:“device_interview”}’
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/devices’, payload ‘[{“definition”:null,“endpoints”:{“1”:{“bindings”:,“clusters”:{“input”:,“output”:}},“11”:{“bindings”:,“clusters”:{“input”:,“output”:[“ssIasZone”]}},“110”:{“bindings”:,“clusters”:{“input”:,“output”:}},“12”:{“bindings”:,“clusters”:{“input”:,“output”:}},“2”:{“bindings”:,“clusters”:{“input”:,“output”:}},“3”:{“bindings”:,“clusters”:{“input”:,“output”:}},“4”:{“bindings”:,“clusters”:{“input”:,“output”:}},“5”:{“bindings”:,“clusters”:{“input”:,“output”:}},“6”:{“bindings”:,“clusters”:{“input”:,“output”:}},“8”:{“bindings”:,“clusters”:{“input”:,“output”:}}},“friendly_name”:“Coordinator”,“ieee_address”:“0x00124b000be8afce”,“interview_completed”:false,“interviewing”:false,“network_address”:0,“supported”:false,“type”:“Coordinator”},{“definition”:{“description”:“1 gang switch”,“exposes”:[{“features”:[{“access”:“rw”,“name”:“state”,“property”:“state”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”,“value_toggle”:“TOGGLE”}],“type”:“switch”},{“access”:“r”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”}],“model”:“TS0001”,“vendor”:“TuYa”},“endpoints”:{“1”:{“bindings”:,“clusters”:{“input”:[“genBasic”,“genIdentify”,“genGroups”,“genScenes”,“genOnOff”],“output”:[“genOta”]}}},“friendly_name”:“Światło Wiktoria”,“ieee_address”:“0xec1bbdfffe9203f8”,“interview_completed”:true,“interviewing”:false,“network_address”:2470,“power_source”:“Mains (single phase)”,“supported”:true,“type”:“Router”},{“date_code”:“”,“definition”:{“description”:“2 gang switch module with neutral wire”,“exposes”:[{“endpoint”:“l1”,“features”:[{“access”:“rw”,“endpoint”:“l1”,“name”:“state”,“property”:“state_l1”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”,“value_toggle”:“TOGGLE”}],“type”:“switch”},{“endpoint”:“l2”,“features”:[{“access”:“rw”,“endpoint”:“l2”,“name”:“state”,“property”:“state_l2”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”,“value_toggle”:“TOGGLE”}],“type”:“switch”},{“access”:“r”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”}],“model”:“QS-Zigbee-S04-2C-LN”,“vendor”:“Lonsonho”},“endpoints”:{“1”:{“bindings”:[{“cluster”:“genOnOff”,“target”:{“endpoint”:1,“ieee_address”:“0x00124b000be8afce”,“type”:“endpoint”}}],“clusters”:{“input”:[“genBasic”,“genGroups”,“genScenes”,“genOnOff”,“genOnOff”],“output”:[“genOta”,“genTime”]}},“2”:{“bindings”:[{“cluster”:“genOnOff”,“target”:{“endpoint”:1,“ieee_address”:“0x00124b000be8afce”,“type”:“endpoint”}}],“clusters”:{“input”:[“genGroups”,“genScenes”,“genOnOff”,“genOnOff”],“output”:}}},“friendly_name”:“Światło Kuchnia Stół”,“ieee_address”:“0x60a423fffeab59d5”,“interview_completed”:true,“interviewing”:false,“network_address”:14996,“power_source”:“Mains (single phase)”,“supported”:true,“type”:“Router”},{“date_code”:“”,“definition”:{“description”:“Smart light switch - 3 gang with neutral wire”,“exposes”:[{“endpoint”:“left”,“features”:[{“access”:“rw”,“endpoint”:“left”,“name”:“state”,“property”:“state_left”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”,“value_toggle”:“TOGGLE”}],“type”:“switch”},{“endpoint”:“center”,“features”:[{“access”:“rw”,“endpoint”:“center”,“name”:“state”,“property”:“state_center”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”,“value_toggle”:“TOGGLE”}],“type”:“switch”},{“endpoint”:“right”,“features”:[{“access”:“rw”,“endpoint”:“right”,“name”:“state”,“property”:“state_right”,“type”:“binary”,“value_off”:“OFF”,“value_on”:“ON”,“value_toggle”:“TOGGLE”}],“type”:“switch”},{“access”:“r”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”}],“model”:“ZM-L03E-Z”,“vendor”:“Zemismart”},“endpoints”:{“1”:{“bindings”:[{“cluster”:“genOnOff”,“target”:{“endpoint”:1,“ieee_address”:“0x00124b000be8afce”,“type”:“endpoint”}}],“clusters”:{“input”:[“genBasic”,“genGroups”,“genScenes”,“genOnOff”,“genOnOff”],“output”:[“genOta”,“genTime”]}}},“friendly_name”:“Światło Kuchnia Meble”,“ieee_address”:“0x60a423fffe93c686”,“interview_completed”:true,“interviewing”:false,“network_address”:5948,“power_source”:“Mains (single phase)”,“supported”:true,“type”:“Router”},{“date_code”:“”,“definition”:{“description”:“Temperature & humidity sensor with display”,“exposes”:[{“access”:“r”,“name”:“battery”,“property”:“battery”,“type”:“numeric”,“unit”:“%”},{“access”:“r”,“name”:“temperature”,“property”:“temperature”,“type”:“numeric”,“unit”:“°C”},{“access”:“r”,“name”:“humidity”,“property”:“humidity”,“type”:“numeric”,“unit”:“%”},{“access”:“r”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”}],“model”:“TS0201”,“vendor”:“TuYa”},“endpoints”:{“1”:{“bindings”:,“clusters”:{“input”:[“genBasic”,“genPowerCfg”,“msTemperatureMeasurement”,“msRelativeHumidity”],“output”:[“genOta”]}}},“friendly_name”:“Termometr Sypialnia”,“ieee_address”:“0xec1bbdfffee4dc3b”,“interview_completed”:true,“interviewing”:false,“network_address”:13760,“power_source”:“Battery”,“supported”:true,“type”:“EndDevice”},{“definition”:{“description”:“Temperature & humidity sensor with display”,“exposes”:[{“access”:“r”,“name”:“battery”,“property”:“battery”,“type”:“numeric”,“unit”:“%”},{“access”:“r”,“name”:“temperature”,“property”:“temperature”,“type”:“numeric”,“unit”:“°C”},{“access”:“r”,“name”:“humidity”,“property”:“humidity”,“type”:“numeric”,“unit”:“%”},{“access”:“r”,“name”:“linkquality”,“property”:“linkquality”,“type”:“numeric”,“unit”:“lqi”}],“model”:“TS0201”,“vendor”:“TuYa”},“endpoints”:{“1”:{“bindings”:,“clusters”:{“input”:[“genBasic”,“genPowerCfg”,“msTemperatureMeasurement”,“msRelativeHumidity”],“output”:[“genOta”]}}},“friendly_name”:“Termometr Dziecięcy”,“ieee_address”:“0xec1bbdfffee23880”,“interview_completed”:true,“interviewing”:false,“network_address”:18664,“power_source”:“Battery”,“supported”:true,“type”:“EndDevice”},{“date_code”:“20180727”,“definition”:{“description”:“Radiator valve with thermostat”,“model”:“GS361A-H04”,“supports”:“thermostat, temperature”,“vendor”:“Siterwell”},“endpoints”:{“1”:{“bindings”:,“clusters”:{“input”:[“genBasic”,“genIdentify”],“output”:[“genIdentify”,“genOta”]}}},“friendly_name”:“Termostat Sypialnia”,“ieee_address”:“0xec1bbdfffec855d4”,“interview_completed”:true,“interviewing”:false,“network_address”:42437,“power_source”:“Battery”,“supported”:true,“type”:“EndDevice”},{“date_code”:“”,“definition”:null,“endpoints”:{“1”:{“bindings”:,“clusters”:{“input”:[“genBasic”,“genGroups”,“genScenes”,“manuSpecificTuyaDimmer”],“output”:[“genOta”,“genTime”]}}},“friendly_name”:“0x842e14fffedb841a”,“ieee_address”:“0x842e14fffedb841a”,“interview_completed”:true,“interviewing”:false,“network_address”:4993,“power_source”:“Battery”,“supported”:false,“type”:“EndDevice”}]’
INFO: MQTT publish: topic ‘zigbee2mqtt/bridge/log’, payload ‘{“message”:“interview_successful”,“meta”:{“friendly_name”:“0x842e14fffedb841a”,“supported”:false},“type”:“pairing”}’
WARNING: Received message from unsupported device with Zigbee model ‘TS0601’
WARNING: Please see: | Zigbee2MQTT.
A w panelu Konfiguracji Zigbee2Mqtt mam taki status:
Próbowałem restartów zigbee2mqtt, jak i wgrałem na nowo zigbee2mqtt. Niestety nic to nie pomogło i przy każdej próbie parowania mam ten sam stan urządzenia.
Co mogę jeszcze zrobić aby poprawnie dodało mi w/w syrenę do Jolki.
