Witam,
Od około 2 tygodni nie działają mi powiadomienia na komórki AIS AI: mob_notify.
Po wywołaniu bezpośrednio usługi z AIS wyrzuca błąd:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/ais_ai_service/__init__.py:2798
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 23:08:09 (2 occurrences)
Last logged: 23:09:10
[2577951424] Cannot connect to host mobile-apps.ai-speaker.com:443 ssl:default [No address associated with hostname]
[2583650608] Error handling message: Unknown error (unknown_error) from 192.168.0.167 (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/112.0.0.0 Safari/537.36)
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiohttp/connector.py", line 1154, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiohttp/connector.py", line 880, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiohttp/resolver.py", line 33, in resolve
infos = await self._loop.getaddrinfo(
File "/data/data/com.termux/files/usr/lib/python3.10/asyncio/base_events.py", line 860, in getaddrinfo
return await self.run_in_executor(
File "/data/data/com.termux/files/usr/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/data/data/com.termux/files/usr/lib/python3.10/socket.py", line 955, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno 7] No address associated with hostname
The above exception was the direct cause of the following exception:
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/components/websocket_api/commands.py", line 200, in handle_call_service
await hass.services.async_call(
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/core.py", line 1784, in async_call
task.result()
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/core.py", line 1821, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/components/ais_ai_service/__init__.py", line 2798, in async_mob_notify
response = await session.post(push_url, json=data)
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiohttp/client.py", line 535, in _request
conn = await self._connector.connect(
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiohttp/connector.py", line 542, in connect
proto = await self._create_connection(req, traces, timeout)
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiohttp/connector.py", line 907, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiohttp/connector.py", line 1166, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host mobile-apps.ai-speaker.com:443 ssl:default [No address associated with hostname]
Ostatnio mały ruch tutaj, ale może ktoś coś podpowie?
