tak czytalem to ale właczyłem i dzialalo, tylko to chciałem sprawdzic
zrobilem i mam taki odzew:
root@XPENOLOGY_DELL:/volume1/docker# ls
apex.ko coral @eaDir frigate frigate2 gasket.ko
root@XPENOLOGY_DELL:/volume1/docker# insmod gasket.ko
insmod: ERROR: could not insert module gasket.ko: Invalid module format
root@XPENOLOGY_DELL:/volume1/docker# insmod apex.ko
insmod: ERROR: could not insert module apex.ko: Invalid module format
Jeszcze raz dla pewności:
/$ uname -a
root@XPENOLOGY_DELL:/volume1/docker# uname -a
Linux XPENOLOGY_DELL 4.4.59+ #25426 SMP PREEMPT Mon Dec 14 18:48:50 CST 2020 x86_64 GNU/Linux synology_apollolake_918+
insmod gasket.ko
potem pokaż co pokazuje dmesg .
Oczywiscie wszystkie polecenia wykonujesz z poziomu użytkownika root
no juz to ismod robilem
dsmeg nie ma w ogole
root@XPENOLOGY_DELL:/volume1/docker# dsmeg
-ash: dsmeg: command not found
root@XPENOLOGY_DELL:/volume1/docker# lsmod
Module Size Used by
tcm_loop 12940 1
iscsi_target_mod 236522 1
target_core_ep 44622 2
target_core_multi_file 26766 1
target_core_file 41362 1
target_core_iblock 19769 1
target_core_mod 929914 18 target_core_iblock,target_core_multi_file,iscsi_target_mod,target_core_ep,target_core_file,tcm_loop
syno_extent_pool 1296536 0
cifs 372254 0
rodsp_ep 76931 3 target_core_multi_file,syno_extent_pool,target_core_file
udf 80226 0
isofs 31403 0
loop 19749 0
hid_generic 1321 0
usbhid 26079 0
hid 94408 2 hid_generic,usbhid
usblp 10618 0
uhci_hcd 22683 0
ehci_pci 3999 0
ehci_hcd 42414 1 ehci_pci
apollolake_synobios 68252 0
ax88179_178a 15422 0
usbnet 20745 1 ax88179_178a
tg3 154417 0
cnic 55581 0
bnx2 74941 0
vmxnet3 42959 0
pcnet32 31986 0
e1000 100121 0
sfc 218790 0
netxen_nic 99003 0
qlge 79767 0
qlcnic 265808 0
qla3xxx 37457 0
sky2 48579 0
skge 30856 0
jme 34901 0
uio 8037 1 cnic
alx 28387 0
atl1c 35074 0
atl1e 28714 0
atl1 31075 0
libphy 23937 1 tg3
mii 4035 5 jme,atl1,usbnet,pcnet32,ax88179_178a
exfat 117655 0
btrfs 956366 1
syscopyarea 3262 0
sysfillrect 3754 0
sysimgblt 2239 0
fb_sys_fops 1314 0
cfbfillrect 3818 0
cfbcopyarea 3326 0
cfbimgblt 2303 0
drm_panel_orientation_quirks 3601 0
iosf_mbi 4234 0
fb 34563 0
fbdev 966 1 fb
video 25321 0
backlight 6096 1 video
button 4756 0
synoacl_vfs 15727 1
hfsplus 92438 0
md4 4337 0
hmac 2961 0
r8168 522467 0
ixgbe 195514 0
igb 173575 0
i2c_algo_bit 5328 1 sfc
e1000e 168333 0
vxlan 32753 0
ip6_udp_tunnel 1903 1 vxlan
udp_tunnel 2355 1 vxlan
fuse 85163 0
vfat 10351 0
fat 53904 1 vfat
crc32c_intel 12849 1
aesni_intel 157811 0
glue_helper 3893 1 aesni_intel
lrw 3541 1 aesni_intel
gf128mul 5546 1 lrw
ablk_helper 1948 1 aesni_intel
arc4 2040 0
cryptd 7882 2 aesni_intel,ablk_helper
ecryptfs 78536 1 btrfs
sha256_generic 11993 0
ecb 2113 0
aes_x86_64 7503 1 aesni_intel
authenc 4076 0
des_generic 16861 0
ansi_cprng 3940 0
cts 4136 0
md5 2833 0
cbc 2712 0
cpufreq_powersave 1126 0
cpufreq_performance 1130 4
acpi_cpufreq 6495 0
processor 23367 5 acpi_cpufreq
cpufreq_stats 2742 0
dm_snapshot 28295 0
dm_bufio 14214 1 dm_snapshot
crc_itu_t 1467 1 udf
crc_ccitt 1467 0
quota_v2 4047 0
quota_tree 7850 1 quota_v2
psnap 1917 0
p8022 1179 0
llc 3569 2 p8022,psnap
sit 15812 0
tunnel4 2261 1 sit
ip_tunnel 13200 1 sit
ipv6 336006 54 sit,cnic
zram 19042 2
sg 26457 0
etxhci_hcd 86330 0
rtc_cmos 9192 2
mdio 3127 3 alx,sfc,ixgbe
mpt3sas 198135 0
raid_class 3572 1 mpt3sas
scsi_transport_sas 24739 1 mpt3sas
megaraid_sas 111352 0
megaraid 43585 0
mptctl 26245 0
mptspi 13124 0
mptscsih 18913 1 mptspi
mptbase 63234 3 mptctl,mptspi,mptscsih
scsi_transport_spi 19223 1 mptspi
megaraid_mbox 28928 0
megaraid_mm 7952 1 megaraid_mbox
vmw_pvscsi 15470 0
BusLogic 21973 0
usb_storage 49426 0
xhci_pci 4650 0
xhci_hcd 104955 1 xhci_pci
usbcore 198691 13 etxhci_hcd,usblp,uhci_hcd,usb_storage,ehci_hcd,ehci_pci,usbhid,usbnet,ax88179_178a,xhci_hcd,xhci_pci
usb_common 2222 1 usbcore
uu 19564 0
Może to kwestia uprawnień do katalogów.
W Syno jest to szczególnie ważne.
Pewnie chodzi jednak o dmesg
Troche dziwne bo w tym watku pokazują wyniki z dsmeg - https://community.synology.com/enu/forum/17/post/19279, tylko to dotyczy starej wersji ale wątpię w to żeby tego nie było w nowszym wydaniu.
Jeszcze pomocna będzi etaka komenda:
modinfo /katalog/do/modułu/gasket.ko
Proponuję także poszukac w systemie katalogu w którym są pozostałem moduly *.ko i tak wgrać te dwa skompilowane.
Teraz zauważyłem różnicę, poprawiłem posta.
dmesg dziala i jest bardzo dlugi nie moge go wrzucic w jednym poście,
a czego w nim szukamy?
to dwie ostatnie linijki na czerwono są:
[ 531.172258] gasket: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
[ 826.661936] apex: version magic '4.4.59 SMP preempt mod_unload ' should be '4.4.59+ SMP preempt mod_unload '
przenioslem do innych *.ko /usr/lib/modules
i tez nie mozna zainstalowac
root@XPENODELL:/usr/lib/modules# insmod gasket.ko
modinfo
root@XPENODELL:/usr/lib/modules# modinfo gasket.ko
-ash: modinfo: command not found
Jest rożnica, jest skompilowany dla 4.4.59 SMP a powinien być dla 4.4.59*+* SMP, weryfikuję dalej …
@bartik22 czy po instalacji Synology robiłeś jakiś update? Na forach czasami ludzie piszą, że mają wersję np. “I am on DSM 6.2.2-24922 Update 3”
Mam dokładnie tak:
DSM 6.2.3-25426 Update 3
Któryś z update’ow wprowadza poprawkę do jądra stąd jest plus na końcu, nie potrafię wgrać tej poprawki do jądra (nie potrafię znaleźć tej proprawki w archiwum Synology), stąd pomysł abyś spróbował zainstalować tak Synology aby po wydaniu polecenia uname -a pojawiło się 4.4.59 bez tego “+”.
ja nie updatowałem ![]()
to juz jest w tym DSM_DS918+_25426.pat
coś piszą żeby dodać plusa …?
Informacyjnie: dyskusja toczyła się dalej wspólnego z @bartik22, ostatecznie udało mi się skompilować moduły pod platformę jakiej używa @bartik22.
Panowie @Cezary.K i @bartik22 dziękuje za cenne dodatkowe informacje, które przyczyniły się do tego sukcesu. Jak widać nie trzeba czegoś używać, mieć aby rozwiązywać problemy z tym związane
Pomocne artykuły:
https://hallard.me/how-to-install-kernel-modules-on-synology-ds1010-dsm-4-1/
źródła Synology - Synology Open Source Project download | SourceForge.net albo Synology Archive Download Site - Index of /download
polecenia:
tar xvf gasket.tar.gz -C /usr/local/src/linux-4.4.x/drivers/staging/gasket
cd linux-4.4.x/
cp synoconfigs/apollolake .config
alias dsm6make='make ARCH=x86_64 CROSS_COMPILE=/usr/local/src/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu-'
# zmodyfikować pliki Kconfig i Makefile w /usr/local/src/linux-4.4.x/drivers/staging aby móc dodać gaspet jako moduł do jądra.
dsm6make menuconfig
dsm6make modules
dsm6make M=drivers/staging/gasket/
#copy file
insmod gasket.ko
insmod apex.ko
Bardzo dziekujemy za pomoc. Czekam na zamówiony TPU Coral pod PCI-e x1. Ja prawdopodobnie będę go uruchamiał pod Linux (bare metal). Dobrze wiedzieć, że jest możliwość uruchomienia Frigate ze wsparciem Coral PCI na Synology.
Wielkie dzięki @macek za poświęcony czas i pomoc zakończoną sukcesem ![]()
System już widzi Corala i działa jak ta lala… 6,5 - 7ms !
Ciekawostka:
