No zrobiłem upgrade by web serwer i wskoczyła wersja Tasmota 10.1.0 by Theo Arends
Komendy to już z 5 razy wklepywałem resetowałem gniazdko i bramkę itd.
0:00:00.002 HDW: ESP8285
00:00:00.051 CFG: Loaded from flash at F7, Count 146
00:00:00.056 QPC: Count 1
00:00:00.065 Project tasmota - Tasmota Version 10.1.0(tasmota)-2_7_4_9(2021-12-08T14:47:33)
00:00:00.555 WIF: Connecting to AP1 Tomato24 Channel 12 BSSId BC:AE:C5:C3:C0:D6 in mode 11n as Gniazdo1...
00:00:03.756 WIF: Connected
00:00:04.008 HTP: Web server active on Gniazdo1 with IP address 192.168.1.44
10:03:42.051 MQT: Attempting connection...
10:03:42.065 MQT: Connected
10:03:42.068 MQT: tele/dom_174409/LWT = Online (retained)
10:03:42.070 MQT: cmnd/dom_174409/POWER =
10:03:42.075 MQT: tele/dom_174409/INFO1 = {"Info1":{"Module":"Gosund SP111 v1.1","Version":"10.1.0(tasmota)","FallbackTopic":"cmnd/DOM_174409_fb/","GroupTopic":"cmnd/dom/"}}
10:03:42.084 MQT: tele/dom_174409/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"Gniazdo1","IPAddress":"192.168.1.44"}}
10:03:42.094 MQT: tele/dom_174409/INFO3 = {"Info3":{"RestartReason":"Software/System restart"}}
10:03:42.103 MQT: stat/dom_174409/RESULT = {"POWER":"ON"}
10:03:42.108 MQT: stat/dom_174409/POWER = ON
10:03:43.489 QPC: Reset
10:03:46.401 MQT: tele/dom_174409/STATE = {"Time":"2022-02-03T10:03:46","Uptime":"0T00:00:11","UptimeSec":11,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Tomato24","BSSId":"BC:AE:C5:C3:C0:D6","Channel":12,"Mode":"11n","RSSI":60,"Signal":-70,"LinkCount":1,"Downtime":"0T00:00:05"}}
10:03:46.429 MQT: tele/dom_174409/SENSOR = {"Time":"2022-02-03T10:03:46","ENERGY":{"TotalStartTime":"2022-02-02T15:20:19","Total":0.001,"Yesterday":0.000,"Today":0.000,"Period": 0,"Power": 0,"ApparentPower": 0,"ReactivePower": 0,"Factor":0.00,"Voltage":277,"Current":0.000}}
10:03:51.632 MQT: homeassistant/sensor/174409_ENERGY_Yesterday/config = {"name":"Tasmota ENERGY Yesterday","stat_t":"tele/dom_174409/SENSOR","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"174409_ENERGY_Yesterday","dev":{"ids":["174409"]},"unit_of_meas":"kWh","dev_cla":"energy","frc_upd":true,"val_tpl":"{{value_json['ENERGY']['Yesterday']}}"} (retained)
10:03:51.667 MQT: homeassistant/sensor/174409_ENERGY_Today/config = {"name":"Tasmota ENERGY Today","stat_t":"tele/dom_174409/SENSOR","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"174409_ENERGY_Today","dev":{"ids":["174409"]},"unit_of_meas":"kWh","dev_cla":"energy","frc_upd":true,"val_tpl":"{{value_json['ENERGY']['Today']}}"} (retained)
10:03:51.699 MQT: homeassistant/sensor/174409_ENERGY_Power/config = {"name":"Tasmota ENERGY Power","stat_t":"tele/dom_174409/SENSOR","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"174409_ENERGY_Power","dev":{"ids":["174409"]},"unit_of_meas":"W","dev_cla":"power","frc_upd":true,"val_tpl":"{{value_json['ENERGY']['Power']}}"} (retained)
10:03:51.731 MQT: homeassistant/sensor/174409_ENERGY_ApparentPower/config = {"name":"Tasmota ENERGY ApparentPower","stat_t":"tele/dom_174409/SENSOR","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"174409_ENERGY_ApparentPower","dev":{"ids":["174409"]},"unit_of_meas":"VA","dev_cla":"power","frc_upd":true,"val_tpl":"{{value_json['ENERGY']['ApparentPower']}}"} (retained)
10:03:51.770 MQT: homeassistant/sensor/174409_ENERGY_ReactivePower/config = {"name":"Tasmota ENERGY ReactivePower","stat_t":"tele/dom_174409/SENSOR","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"174409_ENERGY_ReactivePower","dev":{"ids":["174409"]},"unit_of_meas":"VAr","dev_cla":"power","frc_upd":true,"val_tpl":"{{value_json['ENERGY']['ReactivePower']}}"} (retained)
10:03:51.805 MQT: homeassistant/sensor/174409_ENERGY_Factor/config = {"name":"Tasmota ENERGY Factor","stat_t":"tele/dom_174409/SENSOR","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"174409_ENERGY_Factor","dev":{"ids":["174409"]},"unit_of_meas":"Cos φ","dev_cla":"power_factor","frc_upd":true,"val_tpl":"{{value_json['ENERGY']['Factor']}}"} (retained)
10:03:51.839 MQT: homeassistant/sensor/174409_ENERGY_Voltage/config = {"name":"Tasmota ENERGY Voltage","stat_t":"tele/dom_174409/SENSOR","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"174409_ENERGY_Voltage","dev":{"ids":["174409"]},"unit_of_meas":"V","dev_cla":"voltage","frc_upd":true,"val_tpl":"{{value_json['ENERGY']['Voltage']}}"} (retained)
10:03:51.873 MQT: homeassistant/sensor/174409_ENERGY_Current/config = {"name":"Tasmota ENERGY Current","stat_t":"tele/dom_174409/SENSOR","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","uniq_id":"174409_ENERGY_Current","dev":{"ids":["174409"]},"unit_of_meas":"A","dev_cla":"current","frc_upd":true,"val_tpl":"{{value_json['ENERGY']['Current']}}"} (retained)
10:03:51.907 MQT: homeassistant/switch/174409_RL_1/config = {"name":"Gniazdo1","stat_t":"tele/dom_174409/STATE","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","cmd_t":"cmnd/dom_174409/POWER","pl_off":"OFF","pl_on":"ON","val_tpl":"{{value_json.POWER}}","uniq_id":"174409_RL_1","dev":{"ids":["174409"]}} (retained)
10:03:51.954 MQT: homeassistant/sensor/174409_status/config = {"name":"Tasmota status","stat_t":"tele/dom_174409/HASS_STATE","avty_t":"tele/dom_174409/LWT","pl_avail":"Online","pl_not_avail":"Offline","json_attr_t":"tele/dom_174409/HASS_STATE","unit_of_meas":"%","val_tpl":"{{value_json['RSSI']}}","ic":"mdi:information-outline","uniq_id":"174409_status","dev":{"ids":["174409"],"name":"Tasmota","mdl":"Gosund SP111 v1.1","sw":"10.1.0(tasmota)","mf":"Tasmota"}} (retained)
10:03:57.067 CMD: SetOption19 1
10:03:57.073 MQT: stat/dom_174409/RESULT = {"SetOption19":"ON"}
spróbuję wgrać najpierw tasmota-minimal.bin a potem tasmota.bin zobaczymy.
Robić jeszcze przed tym komendę reset2 w gniazdku czy to nie aktualne?
