Mam komunikat nie potrafię przejść.
Aktualizuje system do najnowszej wersji
Aktualizuje system do najnowszej wersji. Wersja Franek stabilna. Masz Python w wersji 3.7.4. Przejdź na wersję LTS. Status aktualizacji
Robiłem:
$ curl https://raw.githubusercontent.com/sviete/AIS-utils/master/linux/DEV2/apt_upgrade.sh | bash
% Total % Received % Xferd Average Speed Time Time Time Current
100 2133 100 2133 0 0 1751 0 0:00:01 0:00:01 --:–:-- 1752
ok
Upgrade repo
Ign:1 https://powiedz.co/apt dom InRelease
Ign:2 https://powiedz.co/apt python InRelease
Hit:3 https://powiedz.co/apt dom Release
Get:4 https://powiedz.co/apt python Release [3270 B]
Ign:5 https://powiedz.co/apt dom Release.gpg
Ign:6 https://powiedz.co/apt python Release.gpg
Get:7 https://powiedz.co/apt python/3.9 all Packages [18.7 kB]
Get:8 https://powiedz.co/apt python/3.9 arm Packages [252 kB]
Fetched 274 kB in 1s (138 kB/s)
Reading package lists… Done
Building dependency tree
Reading state information… Done
114 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
okAPT install
The following NEW packages will be installed:
libacl
0 upgraded, 1 newly installed, 0 to remove and 114 not upgraded.
Need to get 117 kB of archives.
After this operation, 442 kB of additional disk space will be used.
Get:1 https://powiedz.co/apt python/3.9 arm libacl arm 2.2.53-1 [117 kB]
Fetched 117 kB in 0s (177 kB/s)
Selecting previously unselected package libacl.
(Reading database … 21064 files and directories currently installed.)
Preparing to unpack …/libacl_2.2.53-1_arm.deb …
Unpacking libacl (2.2.53-1) …
Setting up libacl (2.2.53-1) …
The following additional packages will be installed:
game-repo liblz4 science-repo termux-keyring xxhash
Suggested packages:
gnupg unstable-repo x11-repo
The following packages will be upgraded:
apt
1 upgraded, 5 newly installed, 0 to remove and 113 not upgraded.
Need to get 1182 kB of archives.
After this operation, 1749 kB of additional disk space will be used.
Get:1 https://powiedz.co/apt python/3.9 arm liblz4 arm 1.9.3 [79.7 kB]
Get:2 https://powiedz.co/apt python/3.9 arm xxhash arm 0.8.0-1 [64.7 kB]
Get:3 https://powiedz.co/apt python/3.9 arm apt arm 2.2.2 [1001 kB]
Get:4 https://powiedz.co/apt python/3.9 all termux-keyring all 1.4 [34.1 kB]
Get:5 https://powiedz.co/apt dom/stable all game-repo all 1.1 [1050 B]
Get:6 https://powiedz.co/apt dom/stable all science-repo all 1.0 [1054 B]
Fetched 1182 kB in 1s (626 kB/s)
Selecting previously unselected package liblz4.
(Reading database … 21125 files and directories currently installed.)
Preparing to unpack …/archives/liblz4_1.9.3_arm.deb …
Unpacking liblz4 (1.9.3) …
Setting up liblz4 (1.9.3) …
Selecting previously unselected package xxhash.
(Reading database … 21135 files and directories currently installed.)
Preparing to unpack …/xxhash_0.8.0-1_arm.deb …
Unpacking xxhash (0.8.0-1) …
Setting up xxhash (0.8.0-1) …
(Reading database … 21152 files and directories currently installed.)
Preparing to unpack …/apt/archives/apt_2.2.2_arm.deb …
Unpacking apt (2.2.2) over (1.4.9-16) …
Setting up apt (2.2.2) …
Configuration file ‘/data/data/pl.sviete.dom/files/usr/etc/apt/sources.list’
==> Modified (by you or by a script) since installation.
==> Package distributor has shipped an updated version.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer’s version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** sources.list (Y/I/N/O/D/Z) [default=N] ?
*** sources.list (Y/I/N/O/D/Z) [default=N] ? dpkg: error processing package apt (–configure):
end of file on stdin at conffile prompt
Errors were encountered while processing:
apt
E: Sub-process /data/data/pl.sviete.dom/files/usr/bin/dpkg returned an error code (1)
