Teraz działa ale w logach znów kolejne dziwactwa się pojawiają typu
Logger: homeassistant
Source: components/dhcp/__init__.py:273
First occurred: 12:05:33 (2 occurrences)
Last logged: 13:05:33
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/components/dhcp/__init__.py", line 273, in async_discover
for host in await self._discover_hosts.async_discover():
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiodiscover/discovery.py", line 156, in async_discover
sys_network_data = await loop.run_in_executor(None, self._get_sys_network_data)
File "/data/data/com.termux/files/usr/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiodiscover/discovery.py", line 150, in _get_sys_network_data
sys_network_data.setup()
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiodiscover/network.py", line 150, in setup
resolvers = load_resolv_conf()
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/aiodiscover/network.py", line 46, in load_resolv_conf
with open("/etc/resolv.conf") as file:
FileNotFoundError: [Errno 2] No such file or directory: '/etc/resolv.conf'
Source: config_entries.py:1059
First occurred: 11:23:36 (1 occurrences)
Last logged: 11:23:36
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/config_entries.py", line 1692, in _handle_reload
await asyncio.gather(
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/config_entries.py", line 1059, in async_reload
raise UnknownEntry
homeassistant.config_entries.UnknownEntry
Logger: homeassistant.components.sensor
Source: util/dt.py:185
Integration: Sensor (documentation, issues)
First occurred: 11:05:23 (2 occurrences)
Last logged: 11:05:23
Error adding entities for domain sensor with platform mobile_app
Error while setting up mobile_app platform for sensor
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/helpers/entity_platform.py", line 428, in async_add_entities
await asyncio.gather(*tasks)
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/helpers/entity_platform.py", line 673, in _async_add_entity
await entity.add_to_platform_finish()
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/helpers/entity.py", line 776, in add_to_platform_finish
self.async_write_ha_state()
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/helpers/entity.py", line 532, in async_write_ha_state
self._async_write_ha_state()
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/helpers/entity.py", line 570, in _async_write_ha_state
state = self._stringify_state(available)
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/helpers/entity.py", line 538, in _stringify_state
if (state := self.state) is None:
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/components/sensor/__init__.py", line 388, in state
value = self.native_value
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/components/mobile_app/sensor.py", line 113, in native_value
and (timestamp := dt_util.parse_datetime(state)) is not None
File "/data/data/com.termux/files/usr/lib/python3.10/site-packages/homeassistant/util/dt.py", line 185, in parse_datetime
return ciso8601.parse_datetime(dt_str)
TypeError: argument 1 must be str, not datetime.datetime
